Electrical Transmission Towers
I want to find information about tipical layout for 220 kV
electrical transmission tower
RE: Electrical Transmission Towers
The volume you will be most interested in to answer your question is Modern Power Station Practice - EHV Transmission - Volume K (Pergamon Press) ISBN 0-08-040520-7.
This volume gives a fantastic overview. What are the precise details you're after?
If you should be interested on those info check on the T&D Westinghouse Handbook (reprinted by ABB) and the EE Handbook by Fink &Betty.
The selection of a particular design is based on many factors such as project specific requirement, economics, engineering tradition, environment conditions (wind speed, seismic, snow, temperature, etc.)
Some of these tower differences are:
Construction: lattice, tubular, solid section (I-beam), etc.
Materials: steel, aluminum, concrete, wood, composite, etc.
Guided tower, compact arrangement, conventional, single or double circuits with or without under-built
The pictures on the enclose site could help to show the diversity of layout for different towers design:
http://users.castel.nl/~berka01/main.html
