4130 Material with Inconel 625 Inlay
Hi team,
My material 4130 NACE with normalised + hardened + tempered condition. Wanted to weld with Inconel 625.
Can advise whether 4130 needs to do stress relief before welding & PWHT after welding?
RE: 4130 Material with Inconel 625 Inlay
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
Does this means stress relief not required before weld?
I would not stress relieve before welding. You will need preheat.
