Question about ground/bond
We have been told by a Third party inspector the we have run our ground wrong. He quoted DnV but after contacting them I was told that this may be a Norsok standard. Can someone please give me some input.
RE: Question about ground/bond
Questions:
> Did other inspectors OK this before?
> If not, what was your basis for making these decisions?
> What do the other equipment in the vicinity do?
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
The only one that's possibly questionable is the mounting pad isolation:
"Separate bonding shall only be applied for equipment, which is isolated from main structure."
But, the "only applied" implies that if you are using separate bonding, the equipment must have been isolated, so semantically, if your equipment was not isolated, then you were technically violating the standard by having the the separate bonding.
TTFN
