Separate or divide 1 body into multiple bodies?
NX 9.0
The cutter shown in the attached image came to me via email and is all one body. I want to use it in a machine without the shoe/foot and cutter. Is there an easy way to separate this single body into multiple bodies so I can delete/hide the bodies I do not want? I've tried "delete face" with no luck.
Thank you,
Trent
NX 9.0.3.4
RE: Separate or divide 1 body into multiple bodies?
www.nxjournaling.com
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
It appears that you are dealing with geometry imported from another system. If this is the case, you might want to try "heal geometry" and/or the "optimize face" commands to help ensure that you are dealing with good geometry (an 'examine geometry' check wouldn't hurt, either). Commands such as "delete face" have a better chance of success if you start with good, clean geometry.
