Steel Beam to Concrete Wall With Bearing Plate Connection
Hello all
Could someone give me an example or guidance of how to connect a steel beam to concrete wall??
thanks
thanks
RE: Steel Beam to Concrete Wall With Bearing Plate Connection
1) An embedded plate cast into the wall.
2) A shear tab or angles welded to the embed plate.
3) A bolted connection between the shear plate / angles.
4) Short slotted bolt holes to provide erection tolerance.
2) Flexural capacity of bearing plate if you have one.
3) Web crippling and yielding and need for beam stiffeners.
4) Bolt and anchorage design if connection resists tension or shear.
That's a good start.
