HOW TO SIMULATE SYNTHETIC ROPE WITH TENSION ONLY
Hi everyone!
I`m confused about the simulation of synthetic ropes in Siemens NX 9.0.
I need to create e.g. 1D mesh with the relevant properties, but to simulate only tension (not compression, nor bending).
Thank you very much for the quick response.
RE: HOW TO SIMULATE SYNTHETIC ROPE WITH TENSION ONLY
Hi MStas,
Is it possible to use Rod elements? What is the objective of your analysis?
Tuw
Hi Tuw,
Thanks for the response!
Unfortunately, Rod elements won`t give the proper results (I don`t need compression at all).
Maybe it is possible somehow to disable the "compresssion" property in rod element. In such a way it will be an ideal element for me.
I need to simulate displacements of the scheme (I`ve attached the rough sketch).
There`s no difference for me what kind of the solution to be used for the analysis.
It is just necessary to get the proper values of displacements.
MStas
