Providing online passivation layer inside the column
We have a case where passivation layer is missing on the upper part of the column and there is slight reduction in material thickness. Column in under operation since long. Now we want to put the passivation layer inside the column. What are the options available. Is there any way to provide the online passivation layer inside the column.
RE: Providing online passivation layer inside the column
