Spline equation
Spline equation
Hello guys
I'm wondering if it is possible to get the spline equation created in NX.
Does anyone know something about this?
RE: Spline equation
RE: Spline equation
RE: Spline equation
You can also get this from the Information -> spline command.
blazejpop,
If you were expecting a simple polynomial equation such as 3x^2+4x-1, then you will be disappointed. A NURBS curve is actually composed of several equations blended together. If NX were to report the equation used it would look more like what you see on the Wikipedia page (in the General form of a NURBS curve section, about 3/4 way down the page).
www.nxjournaling.com
RE: Spline equation
I thought that spline is just spline, not B-spline or NURBS.
Thanks for your response.
RE: Spline equation
RE: Spline equation
You will see that the general equation of the spline involves some things called basis functions. To construct these, you need some numbers called "knots" (or, collectively, the "knot vector" or "knot sequence").
As far as I know, you can't get the knots from within interactive NX, you have to use SNAP or NX/Open. You can get "knot points" from Information --> Spline, but knots and knot points are not the same thing. The former are numbers, and the latter are points.
