Angle Extension Lines
NX8.5 (still getting up to speed...)
When placing an angular dimension between a centerline and a section hinge line, the extension line starts at the mid-point of the section line, while the extension line at the centerline starts at the end of the line as expected. I have noticed the same behavior with centerlines that are other than 0°.
Is there a setting to default the extension line to the section (or cwnter) line endpoint (so there is a gap), or do I have to manually edit everytime I dimension to these?
TIA!
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
TIA!
-Dalai Lama XIV
RE: Angle Extension Lines
I don't know of any setting that would change it. You could contact GTAC, but I don't think NX 8.5 is going to get much more love and attention.
www.nxjournaling.com
-Dalai Lama XIV
