QUICK DRAWINGS???????
I WANT TO MAKE MY DRAWINGS MORE QUICKLY!
MAYBE ONE OF YOU CAN SEND ME A TIP? FOR EXAMPLE, I LOST TIME TO FIND SYMBOLS LIKE DIAMETER AN OTHER.
ANY HELP I WILL APRECIATE. THANKS.
RE: QUICK DRAWINGS???????
Next you need to get some training from your reseller.
If you do not have access to a reseller, then explore the help files and the tutorial.
Crashj
"The attempt and not the deed confounds us."
I like to thank you MadMango. That kind of tips are very useful.
Are you filling in your title blocks with text or are you using properties from the model?
Bradley
I'am filling the tile blocks with text.
Can You explain me how can I use the properties?
Thanks a Lot!
Go to web site www.nhcad.com Look at Macros/Examples see example 7
Joe Jones explains in detail how to use Config properties very well.
Also look in the left column under Custom Properties.
Good luck
Bradley
The web site you gave me is amazing.
Do you know where can I find other web's similars?
