UG/NX 8.5 Help Balancing Holes
Hey Guys,
is am fairly new to NX just came upon a project that i need help on. I need to make two balanced 180 degree holes for the face shown in the attachment. I am using NX 8.5 can someone help?
RE: UG/NX 8.5 Help Balancing Holes
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
what do you mean by "the hole needs to be balanced" ... my tires need to be balanced ?
Is this part asymmetric to require balanced holes? Balanced within what tolerance?
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Something may be lost in translation, and it may have started with the drawing you attached, not even with what you said.
It could mean many things, and I can't tell which:
"Balance" = equal diameter
"Balance" = equivalent positions
"Balance" = mass will be inserted into holes to prevent shaft vibration.
"Balance" = opposite positions, which would be redundant after also saying "180 degrees".
Each of these interpretations could lead to creating a different model.
...or it means something else. Could you clarify what the holes are for?
The part looks cylindrical, so projecting a hole to enter the surface may require a definition of the geometry of the hole before creating the actual hole feature.
STF
Hopes this makes a little more sense
