Fuming point of Zinc
Looking for a temperature for the fuming point of Zinc, please.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
RE: Fuming point of Zinc
It will start fuming (at low rates) near the melting point (1mm mercury or 1/760th bar vapor pressure at 487 C). If you are producing ZnO, you run the plant above the b.p. for zinc (907 C) and pass cooling/reaction air over the flask to sweep away the ZnO as it forms. Obviously at the low end, the rate of fuming is exponentially less than at the boiling point.
Thank you.
Thomas J. Walz
