Centroids of Faces of a Block
Dear Forum,
I am trying to get the centroids of the faces that make up a block.
I am using the following code to create the block. Now, I want to get the centroids of the faces.
Dim corner_pt(2) As Double
Dim block_feat_tag As NXOpen.Tag
Dim edge_lengths(2) As String
edge_lengths(0) = "iBarStockLength=" & Length.ToString()
edge_lengths(1) = "iBarStockHeight=" & Height.ToString()
edge_lengths(2) = "iBarStockThickness=" & Thickness.ToString()
Dim sign As FeatureSigns
sign = FeatureSigns.Nullsign
corner_pt(0) = 0
corner_pt(1) = 0
corner_pt(2) = 0
ufs.Modl.CreateBlock1(sign, corner_pt, edge_lengths, block_feat_tag)
If block_feat_tag <> NXOpen.Tag.Null Then
ufs.View.FitView(NXOpen.Tag.Null, 1.0)
'MsgBox("First Solid Body tag is: " & block_feat_tag.ToString)
End If
Dim featName As String = Nothing
theUFSession.Modl.AskFeatName(block_feat_tag, featName)
Dim bodyFeature1 As Features.BodyFeature = CType(workpart.Features.FindObject(featName), Features.BodyFeature)
bodyFeature1.SetName("Solid Copper Bar")
Dim nxBlock As NXObject
nxBlock = CType(bodyFeature1, NXObject)
nxBlock.SetName("Solid Copper Bar")
Return nxBlock
RE: Centroids of Faces of a Block
I was doing something similar a while back (looking for the center point of a rectangular face of a block). Below is the code I ended up using, if you run into problems or make improvements please let me know. In my journal theUfSession was a module level variable.
CODE
Function PlanarFaceMidPoint(ByVal planarFace As Face) As Point3d
        Dim uvMinMax(3) As Double
        theUfSession.Modl.AskFaceUvMinmax(planarFace.Tag, uvMinMax)
        Dim ptMin(2) As Double
        Dim ptMax(2) As Double
        'get mid point of given face
        Dim param() As Double = {(uvMinMax(0) + uvMinMax(1)) / 2, (uvMinMax(2) + uvMinMax(3)) / 2}
        Dim pt(2) As Double
        Dim u1(2) As Double
        Dim v1(2) As Double
        Dim u2(2) As Double
        Dim v2(2) As Double
        Dim unitNormal(2) As Double
        Dim radii(1) As Double
        theUfSession.Modl.AskFaceProps(planarFace.Tag, param, pt, u1, v1, u2, v2, unitNormal, radii)
        Dim midPt As New Point3d(pt(0), pt(1), pt(2))
        Return midPt
    End Function
www.nxjournaling.com
Hi Cowski,
Thank you for the code. Except right now I am have problems getting the faces of the Block I've created with the UFUNC functions above.
I've tried the following code:
Dim BarStock As NXObject
BarStock = CreateBarStock(10, 20, 1)
theUFSession.Modl.AskFeatName(BarStock.Tag, featName)
Dim theBody As Body
theBody = CType(workpart.Bodies.FindObject(featName), Body)
Where the function "CreateBarStock" is my custom function which inside there it is using UFUNC ufs.Modl.CreateBlock1.
How do I get the faces of the block? Don't I need to first cast this NXObject to a body? I've tried that and can't get it to work.
Okay. I got it. I changed my function to return the Features.BodyFeature instance. Then I could simply get the faces directly from the returned object.
dim theFaces() as faces
thefaces = barStock.GetFaces()
As far as the centroid of the faces, I found a one line function within SNAP to get me the centroid of the faces of the block. So, then I cycle through each of the faces and get there centroids.
For Each iFace As Face In theFaces
FaceCenter = Snap.Compute.MassProperties(iFace.GetBody()).Centroid
FaceCenterList.Add(FaceCenter)
Next
Thanks again.
Your code doesn't do what you think it does, it seems to me. You are getting the mass properties of iFace.GetBody.
But iFace.GetBody is the body on which the face lies, so it's actually the block. In short, you are computing the centroid of the block.
Here are two ways to get face centroids. The first way uses ExtractFace to get a sheet body; the second way uses the mid-UV trick, which will give you the centroid fro block faces, but not for more complicated ones.
CODE --> vb
Option Infer On
Imports Snap, Snap.Create
Class MyProgram
   Public Shared Sub Main()
      Dim myBlock = Block( {0,0,0}, 6, 4, 2 )
      ' Using Extract to get a sheet body (always works)
      For Each face In myBlock.Faces
         Dim extFeature = ExtractFace(face)
         Dim extBody = extFeature.Body
         Dim props = Snap.Compute.MassProperties(extBody)
         Dim centroid As Position = props.Centroid
      Next
      ' Using the face's UV-box (works only for rectangular faces)
         Dim box = face.BoxUV
         Dim midU = 0.5*(box.MinU + box.MaxU)
         Dim midV = 0.5*(box.MinV + box.MaxV)
         Dim centerPt As Position = face.Position(midU, midV)
      Next
   End Sub
End Class
