Flatten Sheet Metal Part NX10
RE: Flatten Sheet Metal Part NX10
As for your first part, the one you wanted to 'flatten', all that you have to do is once in the Sheet Metal module, select the 'Convert' function and it will convert the model to a valid sheet metal model, as I've done in the attached model, which can then be flattened as well as have the Flat Pattern data created for manufacturing.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
And here is the second part where I added one of the additional sets of flanges that you wanted using the 'Contour Flange' function and then using 'Break Corner' to round off the edges.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
I am trying to reproduce your result. Does it matter which face I select on each operation?
Thank you!
John
Which part are we talking about?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
On the second part did you have to add or change any curves?
John
Hi John,
The first reply was of the 1st part, flatten. Does it matter which face you select?
John
As for the first part, you can select any face but I usually select the one that I would have created first IF I had created the model using the Sheet Metal module in the first place.
As for the second model, I didn't use any of your curves. When you create a Countrou Flange all you need to define is a single curve representing the 'width' of the flange. When you select the edges to apply it to, the corners are notched automatically.
Please review the NX Help files for 'help' with these functions.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
Thank you for your help!
I have been working with GTAC all afternoon trying to get the help files to work. I will try again tomorrow.
John
I'll give you a hint, make sure that you've installed the 64-bit version of JAVA.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I had that installed already...doing a reinstall of the server and documents tomorrow.
