Difference Between MAWP and MEAWP
Whats a Difference Between MAWP and MEAWP, i ve got in PV Eng Software .
RE: Difference Between MAWP and MEAWP
It would help if you spelt out what you think MEAWP stands for as I haven't heard it before and can't find it in any definitions list....
MAWP=Manufactures Allowable Working Pressure / MEAWP=Manufactures External Working Pressure. Sometimes you may see MAEWP. This is my interpretation. I could be wrong.
OK,
It's Maximum Allowable Working Pressure and Maximum Allowable External Working Pressure, ( not "manufacturers...")
Apparently in the latest (2013) code changes it is now just MAWP and is stated as internal or external pressure.
• UG-116 Required Marking
Deleted the term “maximum allowable external working pressure (MAEWP)”
Clarified that “maximum allowable working pressure (MAWP)” can be either
an internal or external pressure
So in your question, MAWP is the maximum internal pressure allowed, MAEWP is the maximum external pressure allowed.
does this make sense?
Thanks for all answer,
Dear ASMEQC,
i agree if MAWP is Maximum Allowable Working Pressure, Not Manufacturer.
Dear LittleInch
Thanks for your great answer, i have find in UG-116 (3).
My mistake not sure what i was thinking.
