TOLERANCES IN SLIP CRITCAL CONNECTIOSN
let us assume that we have a slip critical connection with 2mm gap between the 2 elements, do i have to provide a shim plate for this connection to fill the 2 mm gap or will the tightening process be enough to take care of this small gap??
ôIf you don't build your dream someone will hire you to help build theirs.ö
Tony A. Gaskins Jr.
RE: TOLERANCES IN SLIP CRITCAL CONNECTIOSN
Tony A. Gaskins Jr.
