Is Inspection opening mandatory for air tank designed as per ASME SEC VIII ?
can anyone tell that is Inspection opening mandatory for air storage tank designed as per ASME SEC VIII ?
RE: Is Inspection opening mandatory for air tank designed as per ASME SEC VIII ?
Mike
Now, pure air that these tanks collect, is, pretty much non-corrosive...... however,
the condensate that collects in the bottom of every single air receiver,....... Well, that is very corrosive !
Based on research I have conducted at Lowes and Home Depot, I believe that, below a certain volume, inspection openings may be deleted
Sekar, what kind of tank volumes, pressures and diameters interest you ?
MJCronin
Sr. Process Engineer
Thanks for the response..
To drain out the condensate we can provide a drain valve at bottom centre.. but how could that affect provision for inspection opening ? as i understand inspection opening is to inspect the tank before installation and after fabrication.
and if user has not specified about corrosiveness of service medium and can manufacturer interpret service medium (instrument air, dew point temp. minus 40 Deg.C) as non-corrosive ?
details of the tank,
Volumes range from 20 Ltr to 1000 Ltr
Pressure : Max. 10 barg (instrument air)
Inside Diameter range from 220 mm to 1000 mm
Sekar.
Though user didn't explicitly specify the service as "non-corrosive", since the service medium being instrument air can we interpret that as "non-corrosive" ?
Sekar.
You are probably talking about a couple of 3/4 NPT connections, which can maybe have other uses, to comply. Why not just do it?
Mike
Some clients are not directly specifying about corrosive service. In turn they are insisting to have some corrosion allowance during thickness calculation. Such equipment's have to be provided with inspection openings as per UG-46.
