Low power output - Trumpf resonator
thread380-311289: Low power output - Trumpf resonator
Hi
I like to ask if you manage to solve the problem ?
Sounds very similar to mine ?
Hi
RE: Low power output - Trumpf resonator
For my case, we now confirmed that the gas resonator is leaking, very tiny holes leak, and enough to pass leak test. Need 7 bar of N2 soak in a distill water to see leak. 6 bar no bubble!!
Considering microweld to seal the leak.
Has anyone had this error type on their machine
"safety monitor 1, Circuit 2, index 41 synchronization time exceeded"
Once that comes on the machine is done unless i reboot it about 4 or 5 times
