Micrologix 1100 Memory Module
I have a dead Micrologix 1100 that has a memory module installed. Will a new identical processor work by just swapping out the module or does the new one have to be configured first? IP, configuration, etc?
RE: Micrologix 1100 Memory Module
Of course it is. But they're not answering the phone on a Sunday.
My apologies.
If you have data stored on it that needs to go into a new PLC, the new PLC must have the same firmware revision. The MMI stores that inside, so if the new one is different, it's a mismatch and is ignored.
I think...
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Your question presumes that the memory module has the program code and data backed up on it. If, and only if. your programs are backed up would you be able to transfer to a new controller. This is per:
MicroLogix 1100 Programmable Controllers Bulletin 1763 Controllers and 1762 Expansion I/O
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Thank you for the link. The complete answer is there.
I find the Rockwell site rather impenetrable and wasn't able to find that on my phone out here in 3g land.
