FEM for Space frame one beam is Pinned at its Local Y axis
Hello Everyone.. I have a problem for the space frame direct stiffness method .. If one of the beam is pinned at one end(eg. @ local y axis only), does this mean that the stiffness matrix of this beam would be written differently from other beam elements..
I am currently making a software and I tried to make some modifications on the stiffness matrix for the beam that is pined at one end.. it seemed to work.. but I would like to make sure if my solution is correct..because there may be a better way.
see the figure below for clarifications
RE: FEM for Space frame one beam is Pinned at its Local Y axis
http://people.duke.edu/~hpgavin/cee421/frame-eleme...
It should give you what you want.
By the way, we aren't supposed to put the same question in more than one thread.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
