Curves in drawing view
Hello
Is there a way for NX to treat curve like body in drafting?... So that If the curves or part of the curves are behind the body in some view, then they are hidden. Usually, if you have some component represented just by curves in assembly (e.g. dxf) and you want to show it in drawing, NX shows all curves, as if you can see through body. So far I used view dependent edit to erase curves which are not supposed to be seen. I'm using NX8.5 Thanks.
RE: Curves in drawing view
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
