Simulation of Forces Applied to Pump's bearing & impelsser by ANSYS
Hi every i'm studying a project about reliability of centrifugal pumps,that knows degradations in bearing and mechanical seal.we have to change them about every 3 months so i suggest to simutate forces applied on thoses components in order to know if it's the major cause.
RE: Simulation of Forces Applied to Pump's bearing & impelsser by ANSYS
It's probably solids in the fluid, or dry running. Did you have a question?
i ask if can know forces applied on pipes and impelser by fluid using Ansys
