converting NX 10 drafting to auto-CAD drawing ?!!!!!
i had drawn a full technical drawing using NX 10 drafting and when tring to convert NX 10 drafting to auto-cad
using (2d exchange and dxf/dwg )saving option, no thing happened.
what should i do ?!!
RE: converting NX 10 drafting to auto-CAD drawing ?!!!!!
Double check your settings. Make sure you are exporting out the drawing not the model.
as per my experience NX cannot work with AutoCAD (at least successfully).
Do you have the licenses for the AutoCAD 2d or dxf translator?
Ben Loosli
