Conditional format based on values, characters and spaces (feet and fractional inches)
I'm trying to foolproof a spreadsheet. I would like the user to input feet and inches in a certain format. I need a formula to use in conditional formatting that highlights a cell if the input is not correct.
It must be input as in these examples, 12'-6" or 12'-6 1/2"
The correct procedure is;
1: any number
2: the foot sign
3; a dash
4: any number
5: a space (if using a fraction)
6: the fraction (if using a fraction)
7: the inch sign
Is this even possible?
Thanks, Doug
1: any number
2: the foot sign
3; a dash
4: any number
7: the inch sign
Thanks, Doug
RE: Conditional format based on values, characters and spaces (feet and fractional inches)
But have a look at this bog post regarding the need for error checking in the UDF:
http://excelmatters.com/2014/06/17/udfs-and-condit...
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Have tried this code on a few different entries, and it seems to work.
CODE
Private Sub Worksheet_Change(ByVal Target As Range) If Target.Address = "$A$1" Then If Format(Target.Value, "0" & "'-" & "0") <> Target.Value Then MsgBox "WRONG" Target.ClearContents End End If If Format(Target.Value, "0" & "'-" & "0 0" & "/" & "0") <> Target.Value Then MsgBox "WRONG" Target.ClearContents End If End If End SubChange cell ref as required. The code needs to go into the relevant sheet code windon, not a standard module.
Hope this helps.
been away for quite a while
but am now back
"JOB:" @
For the check boxes: I was able to successfully create a row that works as desired, but if I copy those boxes to other rows, they act strange like in your original sheet (when expanded, movement is not predictable and duplicate boxes are created).
Skip,
Just traded in my OLD subtlety...
for a NUance!
