Reduction in pressure in coker process
Dear all,
Here are several different options to increase liquid production and reduce coke yield in residue coker units. One of the most widely used is try to operate coker drum at low pressure.
But, what are the possible options to reduce further the operating pressure in the coker drum?
Could the minimum pressure limit (alarm) at the wet gas compressor inlet be reduced? We currently operate at 0,4 kg/cm2. Has anyone experience operating at lower pressure at this point?
Has anyone experience installing an on-line water wash in top of main fractionator or condenser to remove salts? In that case, which is the maximum DP reduced with this option?
Has anyone experience implementing any other modifications (increase vapor lines diameter, etc)?
Thanks in advance for your help
Best regards
Best regards
