NXOpen automating changing background colour and graduation
Hello NXers,
We are upgrading from NX4 to NX10 and all the existing files have black backgrounds, white as the selection colour and the old colour palettes.
I am doing a journal to change these in one operation. The current look is a bit too 90s AutoCAD.
This previous post discusses this: thread561-246693: NXOpen Automating switching to Plain background?
This NXOpen class looks promising: NXOpen.Display.Background.BackgroundType = Background.Type.Graduated;
My question is how do I get the instance of the current Display class object? I need that object to call the function above.
From the BasePart.Views() ViewCollection? Does the Part or the ViewCollection own the Display object?
Paul
Paul Turner
CAD & Process Engineer
Mastip Technology
RE: NXOpen automating changing background colour and graduation
Display in this case is just a package, not an object, so you just use the Background class by specifying the package hierarchy:
CODE -->
However, looking at the Background class, it states:
Represents a Background. Background defines how background pixels are displayed. The background resides on a virtual plane at the back of a view. This background is used for display in Studio rendering style and High Quality Images.
So I'm not sure its exactly what you're looking for.
Graham Inchley, Systems Developer, Sandvik Coromant. www.sandvik.com
HP EliteBook 8760w, Win7, 16GB. Developing in: Java | C | C# | KF
Production: NX8.5.3.3 MP4 64bit
Testing: NX9.0.2.5
Hi Graham,
Thanks for the reply.
I need an object reference to be able to set its BackgroundType.
I can't just call:
So my question is how do I get the object reference for the current display?
Paul Turner
Mastip Technology
OK, it seems I was a bit hasty saying you could just call the Background methods directly.
To set the background type this is what I did:
CODE --> Java
View workView = theSession.parts().work().views().workView();
Background bg = theSession.parts().work().views()
	.createBackground(workView, true);
bg.setBackgroundType(Type.PLAIN);
bg.commit();
bg.destroy();
workView.setRenderingStyle(View.RenderingStyleType.STUDIO);
However, as I said in my first post, this is only relevant to views rendered using the Studio or High Quality Image options.
Simple modelling views are not affected.
Looking at the other thread you referenced I can set the background color for normal model views using the wrapper for
UF_DISP_set_color(), but it only changes it for 'Plain' backgrounds. If the view background is 'Graduated' the change is
not seen:
CODE --> Java
double[] rgb = new double[3];
// Red
rgb[0] = 100.0 / 255.0;
// Green
rgb[1] = 100.0 / 255.0;
// Blue
rgb[2] = 200.0 / 255.0;
theUfSession.disp().setColor(0, UFConstants.UF_DISP_rgb_model,
		"MYCOLOR", rgb);
But I can't find a way to change normal model views between Plain and Graduated using the API.
Testing: NX9.0.2.5
