Opening newer Pro-E files in older versions
I am using both versions Pro-E WF4 and WF5. I have gotten WF4 to now open .prt files. However I am more interested in being able to open drawings and or symbols from WF5 in WF4. This has been an issue for several years now, so I'm hoping there are some new solutions or work arounds out there.
RE: Opening newer Pro-E files in older versions
Nope. Models can be opened with the GRCI (I think that's the name) but I don't think it works with drawings.
Thanks, I know that one, as that's what I used to get the .prt files to open. As their tech support suggested I search google, I was wondering if he was hinting of a 3rd party solution.
Those versions of Pro/E are no longer under active maintenance. There won't be any new developments coming out for them. Very few CAD systems have any form of backwards compatibility. About the only thing you can do with drawings and symbols is write them out in DWG or DXF formats to open in the older version of Pro/E. That's seldom useful.
There's an outside company that provides the Creo 3 ability to read other CAD formats, but I forget the name. If I find it I will post. It may offer the ability to push to older versions.
It's a much harder problem to convert drawings than models, particularly if the end result is to be alterable in the target format. Models are just surfaces, but drawings have multiple levels of inter-relationships that aren't typically exposed to the outside. That's why most drawing conversions are to or from things like PDF, which doesn't have much in the way of inter-relationships.
