Autocad 2008-ESC key not working
My Autocad 2008 ESC key is not working. Please help to resolve
Civilsalman
Civilsalman
RE: Autocad 2008-ESC key not working
Does the 'ESC' key work in other applications?
Does anything appear at the command line when you hit the ESC key?
Are you sure Autocad is the application 'with focus' when you're trying to cancel a command?
Can you check and see if there is a different command mapped to the ESC key?
Can you check and see if the 'cancel' command has been removed from the 'ESC' key in the CUI?
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
I believe it is caused by Photoshop, because the ESC key doesn't work in many applications when I have them open at the same time. Excel, for instance.
STF
