Learning the 13th Edition AISC Steel manual
Does anyone have any good tips or references I can use to help me learn how to use the AISC steel manuals to find basic member capacities? It seems a little difficult to decipher everything when you first pick it up. The text doesn't really explain how the tables work or what to look for.
Basically looking for something along the lines of a YouTube series or AISC for dummies type of document that will help give me an overall understanding of how to use the manual.
Thanx
Thanx
RE: Learning the 13th Edition AISC Steel manual
I really wanted to learn brain surgery but the "cutting for dummies" book was out of print.
I know you do not understand what you are saying (I forgive you), but that is quite a flippant and demeaning statement. You are going to have to explain your current education and intents in order to receive good feedback, because based on your OP, the answer is "get a degree in civil/structural engineering". Without that core training, you are heading down a slippery slope; either life-safety or legally-related.
Give us more info, and maybe we can help.
"It is imperative Cunth doesn't get his hands on those codes."
I am a civil engineer, EI but haven't had a chance to do very much structural engineering using the AISC code yet. I was basically looking for a refresher course, tutorial, some brief explanation of getting around the code, AISC design examples, something to help get me familiar with the code again. Possibly something more helpful than the above answers.
13th edition https://www.aisc.org/WorkArea/showcontent.aspx?id=...
14th edition https://www.aisc.org/WorkArea/showcontent.aspx?id=...
http://www.bgstructuralengineering.com/BGSCM14/Con...
master ICC inspector, AWS CWI
I am a civil EIT, didn't have much steel background and found that site helpful. It's actually easier to use than you think (most of the time).
Those books made a lot of Engineers out of those who were curious.
