Does NX have "Physical Motion"?
Hi there!
I'm currently working on a really rough Internal Combustion Engine model in NX 8.5. I've hidden the crank-case enclosure for visibility.
http://imgur.com/iEmGAu7
What I'd like to do is have the Camshaft "bump" the valve pins down as it collides, with them springing back up after collision. Is there any way I can do physical motion simulation in NX?
RE: Does NX have "Physical Motion"?
If you get a license error you should check with your CAD admin to see if your site has any available licenses.
www.nxjournaling.com
If you apply a 3D-contact between cam and the valve, what you describe should happen.
( Provided you are able to set the appropriate values on that contact...)
There are also the NX/Mechatronics which could illustrate the action, i doubt that it can report as much as the NX Motion, but i have never tried it.
Tomas
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Product Engineering Software
Siemens Product Lifecycle Management Software Inc.
(Phoenix, Arizona)
