Wind uplift Tributary Area on Cantilevers
If you are designing a large roof overhang in which the framing has many long cantilevers, is it appropriate to take your tributary wind area (for C&C individual member design/deflection calcs) to consist of the entire cantilevered member? Or should the tributary area be based on the cantilevered length only? Thank you.
RE: Wind uplift Tributary Area on Cantilevers
I run a load case where the wind load is only on the cantilever and base my tributary area on that applied load. I don't know of any code regulation that mandates that though.
