Metal Adhesives
Metal Adhesives
We are gluing metal parts (small vales) together we are using Loctite 270, sometimes it is a thread and other times its a collar. The part are either machined or Metal injection moulded.
Has anyone else had any experiences in this and are we using the right glue? We would want one glue to do all.
Thank you
Wayne.
http://www.loctite.co.uk/loctite-4087.htm?nodeid=8...
Thank you
Wayne.
RE: Metal Adhesives
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
RE: Metal Adhesives
RE: Metal Adhesives
RE: Metal Adhesives
loctite usually has reps you can talk to about this kind of thing - just be a bit careful they're selling you what you need not just what they want to sell you i.e they may push their latest wizz bang cyanoacrylate when some 30 year old technology epoxy is a better fit...
What environment do the parts go into (temp, humidity, chemicals, light exposure...)
What geometry as CoryPad mentions, also what working time you need, what curing time & conditions you want/need, what surface prep you do/can do to your parts, what metals/coatings (some threadlock etc. work better on 'active metals' and don't work as well on passive ones)...
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Metal Adhesives
RE: Metal Adhesives
RE: Metal Adhesives
http://www.belzona.com/products/1000.aspx
http://www.devcon.com/products/products ... milyid=101
