Wrapper methods for UF in "uf_attr.h"
Hi -
I'm doing some NXOpen API programming VB and often use some of the "Wrapper methods" for NXOpen.UF
But in the file: uf_attr.h it seems that there are some (many) calls that is not possible to use as VB, because there is no wrapper method.
ex. Not working:
UF_ATTR_ask_part_attrs_in_file > cant find wrapper method
UF_ATTR_read_value > cant find wrapper method
UF_ATTR_ask_part_attrs > cant find wrapper method
ex. Working:
UF_ATTR_ask_part_attribute > ufs.Attr.AskPartAttribute()
UF_ATTR_find_attribute > ufs.Attr.FindAttribute()
My question is :
Will it be possible to use all the calls from the uf_attr.h in a VB program - and if so - how do I do this?
lklo
ex. Not working:
ex. Working:
My question is :
lklo
RE: Wrapper methods for UF in "uf_attr.h"
UF_ATTR_ask_part_attrs > {part reference}.GetUserAttributes(...)
UF_ATTR_read_value > {part/object ref}.GetStringUserAttribute | .GetNumberUserAttribute | .GetTimeUserAttribute | etc etc
The UF_ATTR_ask_part_attrs_in_file function looks interesting and a quick scan of the NXOpen docs found no equivalent. Sometimes wrapper functions are not added to the NXOpen API because the data returned by the C/C++ function is not easily converted to the managed .net environment (such is the case with some of the UF_BREP functions). Though I'm not sure this is the case for UF_ATTR_ask_part_attrs_in_file. A call to GTAC would probably be required for a definitive answer.
www.nxjournaling.com
Thank you for your answer. I do know that some of the examples doesnt need a wrapper, I know the ****.GetUserAttributes() very well.
But in my current programming project, I'm doing some test to read attributes from NX files placed into a windows file folder(7000+ nx part files as assembly).
My intention was, if it was possible to do this without opening each file, but I dont thing it is possible.
What I have made until now is also working very well.
I have put all files into an array ,aftewards I open each file quite ,and make it workpart quitely temporary, also without making it display.
In this manner it possible to read the partattributes im each file very fast - without have any parts displayed , (only No Part in the NX window)
Another important thing is - when higspeed reading is nesseary - is to set the "SetUpdateLock(True)" from within the Class updatemaneger.
lklo
