in UG NX, how to measure a Min distance between one soild body to the two and more soild bodies
Hi All,
in UG NX, how to measure a Min distance between one soild body to the two and more soild bodies at time(i can measure the min distance between one solid body to another, if we have more than two bodies how we can measure the measure distance between one solid body to the two more solid bodies in a signle shot)
RE: in UG NX, how to measure a Min distance between one soild body to the two and more soild bodies
And if you would have 6 bodies, you would get 15 dimensions , in one shot ?
There is a Clearance analysis which can analyse distances between n components but the function you ask for i doubt exists.
Tomas
When you're in Measure Distance, set the 'Type' to 'Between Object Sets' and you can now set the selection 'Type Filter' to Solid Body which will allow you to select one or more solid bodies for both the 'Start Objects' and 'End Objects' selection steps.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
