Sourced heater with CE Certification can it be sold in US?
Hi All,
We have sourced a electrical water heater with CE certification, but would like to sell it in the US where do we stand on the legal/certification side? As it is not our product we have basically just put our name on it.
Thanks in advance,
Wayne.
Thanks in advance,
Wayne.
RE: Sourced heater with CE Certification can it be sold in US?
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
If you want to include Canada, their rules are similar, but not the same. You usually need CSA or a "Canadian" acceptable reciprocal version of one of the others, such as cUL (the C is for Canada).
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
http://services.ul.com/service/multiple-listing-an...
Z
I would think a listed water heater would be required by local codes in many if not all states.
The ONLY reason to specifically use UL (the company itself) is when your component could be included in someone elses "listed" assembly.
sadly, UL will NOT accept other NRTL companies test data when qualifying the whole system.. all other NRTL's will.
Typically we find Intertek to be MUCH easier/cheaper/quicker to work with.
We request UL and they throw in cUL/IEC/EN/CE/CB scheme for free.. Its typically just slight national differences.
