Metallic Ink Spray for Shielding!
I am trying to stop emi losses by upgrading the current design of our product. And I came across metallic ink that can be sprayed or just painted. Just wondering if this is better than conventional ways meaning using finger stock gaskets, conductive seals, conductive tapes etc? Curious to know what they are like if someone has used them? Are they very expensive?
RE: Metallic Ink Spray for Shielding!
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Sorry for giving a very bland question. I am still researching and talking to our electrical engineers.
TTFN
Unfortunately, 'we' found out the hard way, several times in succession, that you can't effectively and durably ground paint, no matter how conductive the paint itself may be, and no matter how many thousands of dollars a gallon of paint might cost.
We always eventually more or less followed Apple's example, concealing nickel-plated steel inside the plastic, and grounding the steel. Apple was smart enough to design in the steel in the first iteration of the plastic molds; I could not sell even that small bit of prevention.
Mike Halloran
Pembroke Pines, FL, USA
TTFN
Also, what frequencies are you emitting at? This will affect which EMI mitigation methods you use since allowable slot length is directly determined by the wavelength. In this case slot length is defined as distance between electrical contacts along a seam or size of openings. It may be distance between fingers on a gasket, size of punched holes on a sheet metal face, distance between fasteners, etc. General rule of thumb is max slot length of 1/20 of the wavelength for something like 30 dB attenuation (don't quote me on the dB value). Higher frequency -> shorter wavelength -> smaller acceptable slot length.
Doug
To answer your question a bit more directly, spray on shielding will probably not do the job - the sprayed material is too thin for much effectiveness at even very high frequencies and, if the problem is very low frequencies, probably has no measureable effect.
Lot's more I could say but the bottom line is 'get some professional help'. Yes, it will cost the company something (I would guess less than $10K for a short investigation) but the costs of failing may be much higher than that! By the way, RF engineering is where I spent most of my career of over 50 years duration.
@IRstuf - I tried placing a Indium tin oxide film on the screen to stop emi. I bought a small piece of sample 0.15mm thick and stuck it over the touch screen (capacitance). Doesn't really work well for obvious reasons but it was worth a try. Still waiting on copper fingers.
Sorry for such delayed response.
TTFN
[IMG http://tinyurl.com/7ofakss]
Tunalover
