staad pro warnings
staad pro warnings
HELLO,
I am new in staad, working on eccentric and concentric bracing frame.while modelling incase of x bracing i have intersected the members and beams are released MY MZ at start and end. bracings are defined as tension only. but i am getting error of instability warnings and zero stiffness. after using set print 1 command also the warnings are still coming.the model is G+20 and wind and seismic load is applied on 3 d space frame.Can anyone please help me solving this warnings..
thank you
thank you
RE: staad pro warnings
http://www.spiraleng.com
