Existing Concrete Deck - Welding Washers
RE: Existing Concrete Deck - Welding Washers
I believe that there are three purposes:
1) Prevent weld burn through on thin decks (26ga is very thin).
2) Improve uplift weld capacity. This probably isn't an issue in your application.
3) Stiffen the deck in plane. This definitely isn't an issue in your application.
Check this out: Link
Obviously, preventing weld burn through also improves deck shear transfer by preventing it from being ruined altogether. The spacing requirements given for the weld washers looks odd to me. I'm not really sure what their intention is there.
