CATIA VBSCRIPT planar sections an multiple apply
Ok guys here is the problem, I'm trying to simplify my code to avoid unwanted mistakes to happen, because there are still problem using catia with the Sleep function(my computer sometimes is slow)
To simplify my code which is meant to create planar sections of an element using various planes, im currently transforming the code to call the planar section just once and not everytime i have a different plane.
BUT... Catia doesn't like it... at all
I can make the first section, make that the panel of planarSections stays activated but when I select another plane to apply the section on, it selects it but doesn't use it for the section ?!
If you have any idea to help me solve my problem I'll be gratefull.
Here is the code i use
CODE -->
CATIA.StartCommand "Planar Sections"
				WScript.Sleep 100
				oSelection.Search "Name=" & namer ' name of the element to apply the section on
				WScript.Sleep 200
				oSelection.Search "Name=plane0" 'selection of the first plane with which one will be applied the section
				WScript.Sleep 200
				for i=0 to 14    ' loop to reqch the apply button
					WshShell.SendKeys "{TAB}", TRUE
					WScript.Sleep 100
				Next
				WshShell.SendKeys "{ENTER}", TRUE  ''sendkey enter to "clic" on the apply button previously selected
				WScript.Sleep 400
				For j = 1 to (num-1)  ' loop to select the other planes created before this part of code an apply the section for all of them
					oSelection.Clear
					WScript.Sleep 100
					oSelection.Search "Name=plane" & CLng(360/num*j)
					tggt = oSelection.count
					WScript.Sleep 200
					WScript.Sleep 200
				Next
				for i=0 to 15 'loop to reach the OK button
					WScript.Sleep 100
				Next
				WshShell.SendKeys "{ENTER}", TRUE ' clic on OK button
				WScript.Sleep 100
				oSelection.Search "Name=" & "Planar Sections." & "*, all"  'select all the created sections to hide them
				WScript.Sleep 200
				Set VisPropertySet1 = oSelection.visProperties
				VisPropertySet1.SetShow 1 ' hidding the selcion
				WScript.Sleep 200
				oSelection.Clear
RE: CATIA VBSCRIPT planar sections an multiple apply
up?
I found a solution
A bit tricky but, whatever... works just perfectly
I had just to activate the selection , and for that I used WshShell.SendKeys "c:FrmActivate" + "{ENTER}", True just after the selection
CODE -->
					oSelection.Clear
					WScript.Sleep 100
					WScript.Sleep 200
Next
