Scene not available in one of the two models referred by a drawing.
I have a drawing which is referring two different assemblies for sheet one and two. I have created scenes for both the models. When I open the drawing, it showing error message that scene is missing. Even I restart the Catia, any one of the model missed the scene. When I checked the IBM website, it is mentioned that it is bug. Please find the below link. Due to this problem, drawing shows rebuild request and I unable to check in the drawing into smart team. Kindly provide any idea or short cut to overcome this problem.
http://www-01.ibm.com/support/docview.wss?uid=swg1...
Suresh
Suresh
RE: Scene not available in one of the two models referred by a drawing.
Please check if the scenes are available in the assembly files.
Sudhakar.
I checked the scene if it is available in assembly and found that it is not available in either assembly or product.
Mean while, I got short cut to overcome this problem. if we check in the model in smart team and check out one time, both the scenes are available.
Suresh
