Custom edit of mass in parts list dft
I want to create a parts list in draft environment and add the weights of the parts and the assembly in total.
That works fine for me when i add a column mass. The mass shows up in the column and for the total assembly.
But...
We produce furniture and i want to have the weight of our package in total. That package includes also the furniture fittings in a little bag.
We have the mass of that bag and i want to insert that weight direct in a "dummy part" for a "furniture fittings bag".
So i want that the inserted mass of that bag shows up in my part list and is calculated in the total mass of my assembly (package).
How can i do this?
RE: Custom edit of mass in parts list dft
Create a new part with a name of your choosing. Make some kind of feature like a 1 inch cube or something. Go to Inspect/MV Properties, click the "User-defined properties" box and enter the needed mass in the mass box and something in the volume box (just can't leave it at zero) and close the dialog (I attached a jpeg). You can delete the feature after entering the mass and volume numbers but you will need a feature present to change them. Then you can delete that one again. Save the part and insert it into the assembly.
Hi bshand,
Thank you for this tip, that's the tip I needed!
Friendly greetings,
Matthias
