Calculation of Collapse Pressure for Perforated Pipes
Hi all
Can you please guide me on how to calculate the collapse pressure of perforated Pipes.
My case is to make a 2mm thick Pipe (1500 mm long) to be used as a filter element with perforations. The wire meshes shall be wound around the perforated pipe.
Design pressure - 5 kg/sqcm(g), which shall be the maximum differential pressure across the Perforated pipe
Required No. of holes on Pipe = 1250
Hole diameter = 8 mm
Hole pitch = 13 mm, triangular pitch
Are there ready references ??
Thanks in advance
Thanks in advance
RE: Calculation of Collapse Pressure for Perforated Pipes
Flow is from outside to inside (external pressure design case of 5 kg/sqcm)
Material of construction of Pipe - SA240-304
Is 5 bar differential the maximum pressure outside, assuming zero inside and a fully blocked filter?
Is a fully blocked filter realistic?
The difficulty of this approach is why you normally go inside to out, plus it makes the capture of dirt a lot easier.
However assuming you're stuck with your design and flow and not bothered about debris, I think you will either have to model this in FEA or you may just make one and test it. Try a cylinder 1mm thick or 0.5mm thick and see if it holds up.
Never have run across a method to calculate the collapse pressure of drilled pipe.
Some observations:
[ol 1]
/ol]
A justification to this is that a tube buckles by forming an oval (or a higher order waved shape), and longitudinal weak lines passing through the ligaments will be the source for bending to the collapsed shape.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
