Size of Opening / Nozzle Size
I have a tank with no data for the nozzle and it is to be determine by the engineer. How do we determine the size of the nozzle? The flow rate is given. Can the nozzle size be determined by Q=aV formula to get the size?
Thank you
Thank you
RE: Size of Opening / Nozzle Size
There are some other considerations such as location of nozzle, function of tank, minimum nozzle size, fluid level height, etc. that may influence your decision.
Inlet nozzles are to be sized based on ρ∗v2 as follows:
• ρ∗v2 max (kg.m.s –2)= Around 1500 if no inlet device is foreseen
• ρ*v2 max (kg.m.s –2)= Around 3000 if half pipe or baffle inlet device is foreseen
• ρ*v2 max (kg.m.s –2)= Around 6000 if Schoepentoeter or other vane pack inlet device is foreseen
Outlet nozzles are to be sized by the same criteria which are used for line sizing.
From this drawing all nozzle size must be shown.
http://red-bag.com/engineering-guides/249-bn-eg-ue...
