API650 Tank annular bottom plate and bottom plate
Hi All,
If the tank bottom plate is 6mm and the annular bottom plate required also 6mm (as per table 5.1). In this case is it ok not to have the separate annular plate instead just extend the bottom plate to project 50mm outside the wall? which means wall just stit on the bottom plate.
much appreciated if some one clarify this.
Regards'
Magesh
Regards'
Magesh
RE: API650 Tank annular bottom plate and bottom plate
How to check wheather annular plate is required or not?
