Cannot run an analysis when changing section oreintation in SAP2000
Hi There
I am a new user of SAP2000. I am designing a cold formed steel truss and I ran it few times. It worked perfectly.
However, when I activate the Extrude view, I realize the orientation of some channel sections are wrong. Therefore, I changed the orientation of the Channels by rotating them (degrees). But this time, I cannot run the analysis anymore! No design actions can be calculated and all the members will be in red and N/C.
Does anyone has an idea how to fix this problem?
Thank you
Thank you
