how would a machinist program this?
This might not be the correct thread but I have a part with some curves/radii in it, and I want to make sure I am dimensioning it as easy as possible for the machinist. The way it is currently dimensioned I know that you can figure out the curves if you do all the math, but how would a machinist actually go about and do this? Do they have a program where they can easily drop these radii in and make them all tangent? Or would it be easier if I gave center locations to all of the radii? Also is it easy for a machinist to program a profile for whether the machine should follow the outside or the inside of the radii? I have several parts like this and i want to make sure the drawings make sense. Please see attached.
RE: how would a machinist program this?
If you don't know much about machining (and even if you do) you'll do more harm than good by trying to make a funky drawing "made for the machinist" rather than an appropriate design drawing that adequately defines the part and shows the design intent.
The best thing you can do for the machinist is to not over-tolerance your drawing. If a three-place dimension is defined as being +/- .005" then you should really ask yourself if you need that tight of a tolerance on fillet radii.
tl;dr: If there's enough information on the print to /draw/ the part; there's enough information on the print to machine the part. Your desire is great. It's good that you wish to look at your output as if you were the person making the part. That will solve a great many things, but at a certain level 'unintended consequences' arise.
All that said, the only exception is if you're making actual "shop drawings" at which point you should be asking your shop (and honestly shouldn't have to ask, unless you have a supervisor that can answer them)
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
Didn't you have a similar question about dimensioning curves a few weeks back, or am I thinking of someone else?
Dimension it based primarily on functionality as JNieman says.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
... e.g. by providing center locations for radii, and providing coordinates for tangent points. If that results in the part being overconstrained, mark some of the dimensions as reference.
... but first, if at all possible, go find the machinist who will actually make the part, and have a nice chat about how to dimension the part to make manufacture and inspection easy and straightforward.
Bring doughnuts.
Mike Halloran
Pembroke Pines, FL, USA
Don't bring food or drink into a temperature controlled shop.
Don't rest drink or food on a machine way or a surface plate.
Mike Halloran
What is the material? Aluminum, cast iron gray, cast iron ductile, cast steel, cast austenitic stainless steel. Is this a cast part needing milling on the end or a flame cut part or a forged part or a bar stock part?
Is the part heat treated after machining? Is the part plated?
How many do you need to machine one, 10, 100, 10,000?
I was a N/C and a CNC programmer for 12 years and machined many different parts on many different machines. I manually and later used computer assist to program many parts and used paper tape/mylar tape. Machines today have a nice interface and many programming features built into the controls. Many of my programs were manually written and manually put on tape. Give me what you want and I can make you a program. Give me all the information.
Bill
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
