More GRIP Help Please!
Good evening,
I'm after a bit of GRIP help if possible? I have a GRIP program, probably downlaoded from here, it was ages ago when I found it and can't remember, sorry. It currently generates OTP/PT values for points on a drawing, however generates them to a table which is made of lines and text. Is there a way it can be edited to generate a Tabular note or something like that?
I do have some Journals that do a similar thing, but can't for the life of me work out how to use them properly!
All files attached, thanks in advance.
RE: More GRIP Help Please!
You need to have the .grs Grip Source to share.
Tables are newer than when GRIP was last updated about 18 years ago. I doubt you will find a GRIP routine to format the data into a table.
You can get the point data into a txt file which can be loaded into Excel and then manually create a table.
Ben Loosli
