ANSYS STRUCTURAL-Leaf Spring
1. An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present. Please see the Troubleshooting section of the Help System for more information.
2. The solution failed to solve completely at all time points. Restart points are available to continue the analysis.
3. The detected initial penetration/gap is relatively large for certain contact pairs. This may produce inaccurate results for Bonded and No Separation contacts using formulation other than MPC. This large penetration/gap can be identified by generating the initial contact results.
4. One or more remote boundary conditions is scoped to a large number of elements which can adversly affect solver performance. Consider using the pinball setting to reduce the number of elements included in the solver.
5. The unconverged solution (identified as Substep 999999) is output for analysis debug purposes. Results at this time should not be used for any other purpose.
6. One or more contact regions may not be in initial contact. Check results carefully. Refer to Troubleshooting in the Help System for more details.
7. One or more bodies may be underconstrained and experiencing rigid body motion. Weak springs have been added to attain a solution. Refer to Troubleshooting in the Help System for more details.
8. Although the solution failed to solve completely at all time points, partial results at some points have been able to be solved. Refer to Troubleshooting in the Help System for more details.
CAN ANYBODY HELP ME OUT WITH THIS?
RE: ANSYS STRUCTURAL-Leaf Spring
