Corrosivity of fresh water saturated with O2
Dear all,
Is there anybody who has some reliable sources or who could tell me more about "corrosivity of fresh water saturated with O2" ? All types of information will be welcome, close or open loop, any type of material ...
Thank you in advance, kind regards.
RE: Corrosivity of fresh water saturated with O2
http://www.ce.sc.edu/deptinfo/members/faculty/ray/...
http://www.roscoemoss.com/wp-content/uploads/publi...
http://www.corrosion-doctors.org/Cooling-Water-Tow...
http://www.euro-inox.org/pdf/map/paper/Ledion_wate...
Dejan IVANOVIC
Process Engineer, MSChE
CR = CRB x FT x FV where CRB is the Base Corrosion Rate, FT is the Temperature Adjustment Factor and FV is the Flow Velocity Adjustment Factor
There is a very good and detailed explanation on how to get the above values. I have used this equation in the past to carry out corrosion calculations for oxygenated water which were approved by the Client.
Suraj Tinani
Regards.
Why are you asking about "close (sic) or open loop" and then oil and gas field - the two are not usually integrated. What is the specific application? For an oilfield water injection system, a corrosion model that is more appropriate would be Andijani & Turgoose
thread338-249018: A relationship between dissolved oxygen and corrosion
http://www.ncbi.nlm.nih.gov/pubmed/14982171
The model applies to metal loss of carbon steel. You also ask about "any type of material" - oxygen with corrosion resistant alloys brings about an increased likelihood of pitting corrosion, crevice corrosion and stress corrosion cracking.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Concerning fresh water systems, the data I am looking for are graph or formulas which could directly lead to calculation of the corrosion rate in function of dissolved oxygen content, temperature, oxygen partial pressure, total dissolved solids ... Does it exist ?
Then I've read about the effects of oxygen entry on corrosion mechanisms but I would like to have a value to "set" a limit of how much oxygen is allowable in the systems. That is a really general study but I need some particular values to have a reference.
At the moment data on carbon steel would be more than welcome, then if you have anything else about different materials, feel free to mention it.
Unfortunately I can not access the documents you mentioned but I keep on going.
Thank you for your answers, kind regards.
