Detail View with out a parent
So I have a 14 sheet drawing that I have to make some changes to. I have a detail view BA when I right click the view in the part nav to try to navigate to the parent that option is not available. I'm trying to figure out how this can be a detail view with out a parent to associate to. Any Ideas?
RE: Detail View with out a parent
NX V8
My guess is that is a simple base view with the border manually edited to look like a detail view.
So rmc on the view -> boundary -> change to automatic rectangle
Jerry J.
Milwaukee Electric Tool
http://www.milwaukeetool.com/
I'd guess the detail view was made independent, then the parent view was deleted.
www.nxjournaling.com
My guess is that the view has been made to Independent detail view.
Its not a base view with an edited border. That's what I thought at first but in the parts nav it is listed as a detail view.
If you deleted a parent view I thought it deleted all if its children with it?
How do you go about making a detail view independent I haven't seen this done yet.
Quote (cpbpilot)
Create a detail view then right click on it and choose "make independent". Now delete the parent view; you will find that the independent detail view remains (a dependent detail view will be deleted with the parent view).
OK. I guess that explains that!
Thanks for all the help guys!
